hub won't disengage??
Old Aug 31, 2004 | 05:52 PM
scrambler123's Avatar
Default hub won't disengage??
The left front hub on my xplorer 400 will not disengage anyone know why this would be happening? the right one is functioning properly.
Old Aug 31, 2004 | 06:06 PM
Whitewater's Avatar
I don't know??? I think my sportsman 500 has an intermittent left hub issue, too.
Old Aug 31, 2004 | 06:20 PM
scramblerXrated's Avatar
only thing i can say is to start by checking the hub fluid level, or just change it altogether.
i have had an intermittent hub issue as well,,,, but i can get it to disengage by going in reverse, then forward.
X
Old Aug 31, 2004 | 06:21 PM
Whitewater's Avatar
Same.
Old Aug 31, 2004 | 06:25 PM
this one is stuck and has been for a while going in reverse does not help.
Old Aug 31, 2004 | 07:40 PM
MnFriesen's Avatar
did you recently grease it?? I am not 100% sure if the xplorer has spots to grease but on our magnum we greased it and then the hub wouldnt disengauge....then we found out the dealer gave us the wrong type of grease...the stuff he gave us was to heavy and it would make it engauge
Old Aug 31, 2004 | 08:41 PM
DGScrambler400's Avatar
when going in reverse than forward again fixes it, that means you need to change your hub oil
Old Aug 31, 2004 | 08:52 PM
ATVman00169's Avatar
this used to happen to me all the time. leave it in 2wd then put it in "N" and trun it left n right a few times, then go in R, and back in to drive, if that don't work you may need a new hub spring, i did. i have takeing my hubs apart lots of times. mostly cuz i keep riping my 4 wheel drive boots.[img]i/expressions/face-icon-small-mad.gif[/img]
Old Aug 31, 2004 | 09:39 PM
the boot on that side is ripped and it has lost some fluid could that be part of it?
Old Aug 31, 2004 | 09:56 PM
NBsportsman's Avatar
Yep thats your problem.....
