300 ex gearing/sprocket
Old Sep 2, 2004 | 11:11 PM
zoe17's Avatar
Default 300 ex gearing/sprocket
I have a 2001 300 ex with a T-4 pro-circiut pipe,K&N, airbox mod, I am running a 168 main jet and it seems fine. I do not know if it is stock bore and stock cam. With stock cam/bore what is about the largest size main jet to run good.
Also I have baja T-9,s and 22" hole shots, If I mostly ride woods and really don't care about top end what teeth conf is best.
Thanks in advance for your help.
Old Sep 3, 2004 | 12:59 PM
Hondanutcase's Avatar
You say it runs fine I would leave it alone but, a 168 main sounds to big to me. Check your plug. Jets are cheap play around withem.
Old Feb 10, 2005 | 01:06 AM
chazekxt's Avatar
168 wow i have a full pipe k a n and a only 125 main hmmmm..
