H\N\R trans switch 00-02 magnum500s
Old Sep 3, 2004 | 12:12 AM
rmkcac700's Avatar
Default H\N\R trans switch 00-02 magnum500s
rear transmission switch failure every about 200 miles. Not abusive, and no kids riding it.
any suggs fellas
thX
Old Sep 3, 2004 | 10:31 PM
rmkcac700's Avatar
[red][big]NOBODY AT ALL[/red]
Old Sep 3, 2004 | 10:33 PM
rmkcac700's Avatar
[red]hi[red]
Old Sep 3, 2004 | 10:56 PM
BigBadScrambler's Avatar
Bad ground?? Dunno?. If it is going bad that often, then there has to be something more going on than just the switch. What is going wrong with it? Is it frying out?
Old Sep 4, 2004 | 12:55 AM
rmkcac700's Avatar
it just completely loses cont between powerin, and power out on any function. not loss of one or the other.
I think I may have gotten it. he had a lot of moisture in the gearcase and the condensation was goofin up the switches in it.
I cut open one of the other old ones and saw corrosion in the switches, most likely water.
Old Sep 4, 2004 | 12:59 AM
You may want to put some dielectric grease around it next time them. Should seal it up
Old Sep 4, 2004 | 01:11 AM
rmkcac700's Avatar
the moisture was coming from in the gearcase. It is sealed from the outside. the oil was milky it had so much water in it.
Old Sep 4, 2004 | 01:23 AM
Possibly a bad seal then?
NRA+1
1) Engine problems..
10
Sep 20, 2015 08:47 PM
nick c
Sep 13, 2015 10:08 AM
alzgarvin
Sep 11, 2015 08:53 AM
MrTrashMan2U
Sep 9, 2015 11:11 AM
toonces
Sep 5, 2015 01:14 PM
