Sportsman 500 belt tension question, new drive clutch and belt seems to tight
Old Sep 5, 2004 | 11:50 PM
pol5002's Avatar
Default Sportsman 500 belt tension question, new drive clutch and belt seems to tight
I put on a new drive clutch on today. After install the Sportsamn 500 creeps, or cuts off if I apply the brake. The belt tension is tight. Before I take the driven clutch off I just wanted to check to see if I most likely need to adjust the spacers in the driven clutch. If so do I add them to make the belt looser or take them away.
Thanks
MikeyBoyesq
Nov 27, 2020 02:44 PM
jgiljr
Aug 21, 2015 06:15 AM
Polarisman1123
May 25, 2015 10:07 PM
Polarisman1123
May 25, 2015 10:03 PM
ZJnut
Dec 30, 1999 08:33 PM
