Chain tensioner, worth it?
Old Sep 5, 2004 | 11:58 PM
ScRaMbLeRiZeD's Avatar
Default Chain tensioner, worth it?
I do a good amount of jumping and was wondering if its worth it to get a chain tensioner. If so is hpd better than hsp? And how long does it take to install?
Old Sep 5, 2004 | 11:59 PM
tbsleeper's Avatar
our good old friend modquad has one for sale right nwo on ebay...try to get it before it ends!!! its a hsp one theyre both the same just different color rollers
Old Sep 6, 2004 | 12:07 AM
Thanks for the info I'll bid on it.
Old Sep 6, 2004 | 12:24 AM
mudmaster250's Avatar
get it, i got a new chain and put it on and my chain has hardly even changed tension in over three months. and i ride it through tons of whoops and stuff and jump it. well worth it get it.
Old Sep 6, 2004 | 12:36 AM
BigBadScrambler's Avatar
$50 chain tensionor or a $1000 tranny case when your chain snaps and cracks the case. WELL WORTH IT!!!
Old Sep 6, 2004 | 03:24 PM
Skrammy's Avatar
I have just recently bought and installed a chain tensioner on my '01 500 4x4. It was pretty easy to install. I think mine was the HPD unit. It has a grease fitting as the HSP does not. HPD's comes with a drill, tap, and bolts to mount it. You will have to cut off the chain slide mount on the bottom of the swing arm. I can't run my swing arm guard now untill I modify it to fit around the tensioner. It is worth it though. I had to adjust my chain after every other ride before. I haven't had to do it once. I have been riding about 6 times since I put it on. If you get the greasable one, make sure the zerk fitting doesnt rub the chain .
Chad
Indy, IN
Old Sep 6, 2004 | 03:56 PM
scramblered's Avatar
get the tensioner,i will make your sprocket and chain a better use.
HPD or hot seat,both worth the money.it take about 20 min to install.
drill the holes and fit it on the swingarm.
mrtidy
Feb 3, 2016 05:00 PM
kodiacrunner
Oct 4, 2015 11:52 AM
r1pilot83
Sep 27, 2015 07:38 PM
kbazzy
Sep 26, 2015 11:26 AM
bvolks
Sep 13, 2015 12:57 PM
