300EX shock adjustment
Old Sep 6, 2004 | 12:06 PM
Hondaguy108's Avatar
Default 300EX shock adjustment
How do I adjust the rear shock on my 300EX?? The front is real easy and has themhole to put the tool in while the rear has nothing like that. Is there a trick to this?? thanks
Old Sep 6, 2004 | 12:10 PM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
OK, it's been a while since I owned a 300, but doesn't it have a collar that you turn, just like the front??? Or is it threaded??? I have a collection of about a dozen shock wrenches. I have never found any one that works perfectly with every bike.
http://www.off-road.com/atv/suspension/shockadj.htm
Old Sep 6, 2004 | 12:20 PM
It has the collar on the top but it is real hard to turn. Do i have to get the wheels off of the ground or something cuz its real hard to turn
Old Sep 6, 2004 | 01:09 PM
Red Rider
Yes, it will be easier if you put the frame up on a crate, and unload the weight from the rear wheels. Rear shocks are a pain! At times, I have used a large screwdriver, and pried against something. And, in on position one shock adjustment wrench will work, and in another position it will have to be another one.
Old Sep 6, 2004 | 05:54 PM
300exRiderJay's Avatar
I use a flat head screwdriver and a hammer.
Old Sep 7, 2004 | 12:45 AM
TractorPacker's Avatar
Do you have a balloon?
I unbolted mine and did it on the bench. It only has 2 bolts holding it in and it is tight up in by the air box.
Bonzhonda300ex
TheATVSuperStore
Sep 17, 2015 01:21 PM
ScopeZ_
Sep 13, 2015 07:55 AM
Nosniborpapa
Sep 12, 2015 05:54 PM
Wiley wolf
Sep 7, 2015 08:32 PM
OutRacing
Technical and How-To Articles
Sep 3, 2015 07:49 AM
