Low Beam + High Beam same time
will on the sportsman. its easy. you can't have high and low.. your Top light has a low and high, the bottom ones only have low.. in side the speedo. "pod" you can hook up the low to the top light. so when low beam is on all 3 light will be on, instead of just the bottom ones.
Hey ATVman: Are you telling me that my pod on my sp700efi has a low beam that just does not get used? I am preparing to do the lights mod this week. The one where you jump the high beam pod with a diode so the two lows stay on also. If I wire it correctly, will I be able to have all three in true low beam?
Bloomer
Bloomer
do a search on here.....for light mods...lots of old topics will tell ya the easy way to do it for under a buck....or just push it carefully between the two settings ....it usally never moves off it for me !
you don't need a kit.. its a do it your self thing.. we did it to my ol mans wheeler. very easy.
Tom128
The kits cost $10-$20 on ebay. I went to radio shack and purchased a four pak of diodes, heat shrink, and some wire for about $6. I have enough to do four quads. Im' sure you are bound to have some friends that would like to do this mod also.
Good Luck
Bloomer
Good Luck
Bloomer
