Swing Arm Bushings
Old Sep 6, 2004 | 04:34 PM
Skrammy's Avatar
Default Swing Arm Bushings
Alright, time to change the bushings on the Scrambler. I got the clutch cover off so I could move the back cover so I can get to the swing arm bolt on the left side. Will i have to remove the secondary clutch to access the bolt? If so do I just remove the center bolt and the clutch comes off the trans? Or is there more to it than that? Anyone know what size the swing arm bolts are? They look like they will require an inch and three quarter socket. Any tips on doing the job? Thanks
Chad
Indy, IN
Old Sep 6, 2004 | 04:55 PM
thewayout420's Avatar
yeah remove the driven clutch by taking out that one center bolt,then remove the 3 bolts behind the clutch that hold the back cover on and you can bend it just enough to get the socket onto the bolt.the socket you need is a 1 3/4"..remember to use locktite when putting it back together..
Customer Service #1
May 15, 2020 08:46 AM
fd24
Jan 16, 2019 08:59 AM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
Alex G.
Sep 19, 2015 06:34 PM
