44mm Lectron??
Old Sep 8, 2004 | 12:03 AM
Dingo2's Avatar
Default 44mm Lectron??
Does anyone run a 44mm Lectron that Mr. HP sells for $350.00. If so, just curious how much better it is than stock. It dyno's at 2 peak hp less than the 46mm. Any 44mm owners out there?
Old Sep 8, 2004 | 07:38 PM
DSaholic's Avatar
I have one and love it. The set up is easy and the power on the top end is way better than stock. If you do get one make sure that you get a 90 degree bend for the top of the carb as it makes the throttle pull way better.
Old Sep 8, 2004 | 07:44 PM
Dingo2's Avatar
Dsaholic..your running a 44mm right? Not the 46mm? Did you buy it from Mr. HP?
Old Sep 9, 2004 | 09:16 AM
Dingo2's Avatar
Anyone have first hand comparison between the 44 and 46HV Lectrons?
Old Sep 9, 2004 | 10:30 AM
DSaholic's Avatar
Yes I am running the 44mm. I didn't buy it from Mr HP but I did send it to them to set it up and dyno tune it to the CT pipe that I bought from them. 650viper is running the 46 and it runs real good. The difference between the two is about 2-3 hp I think but the power curve is about the same. I have the dyno runs with the 46 and the 44 and the CT pipe. I was impressed with the 46 but I think that I am going the go with the boondocker NOS setup instead of upgrading to the 46.
Old Sep 9, 2004 | 01:18 PM
DSengineer's Avatar
Has been here a long time!
Can you run the stock thumb throttle with the Lectron 44 or does it require the Moose billet setup like the 46 does?
Does the 44 exhibit the same sticky/stuck shut issues that some are reporting with the 46HV?
Old Sep 9, 2004 | 01:49 PM
Dingo2's Avatar
Dsaholic..anyway you could post pics of the dyno runs?
Old Sep 9, 2004 | 01:56 PM
DSaholic's Avatar
Well I have never had the slide reall stick on me but I do keep it clean. When I got my 44 I got a throttle with it but I am sure that you can modify the stock one to work just fine.
I don't have a scanner to scan the dyno runs so there is really no way for me to post them. Sorry. I know that on a stock bike with the CT pipe and the 44 mm with open air box setup it made around 48 hp on the dyno.
Rockey
Sep 30, 2002 10:59 PM
Knutz
Sep 13, 2002 01:58 PM
Hightower
Jun 1, 2002 10:10 PM
dschris
Apr 13, 2002 11:26 PM
dschris
Apr 13, 2002 06:47 PM
