05 400ex gets reverse and 450R plastic.
TRX400EX
$5,799 BASE MSRP
Available September 2004
Long a favorite of the serious sport ATV pilot, the TRX400EX is the perfect dune-carving combination of class-leading performance and handling. And now, thanks to wicked new styling straight off the TRX450R, an all-new reverse gear and newly revised gear ratios, the TRX400EX is ready to take the art of sport ATVing to a whole new level.
Enlarge
ENGINE
Engine Type 397cc RFVC air-cooled dry-sump single-cylinder four-stroke
Bore and Stroke 85.0mm x 70.0mm
Carburetion 38.0mm piston-valve with accelerator pump
Ignition CD with electronic advance
Starter Electric
Clutch Manual
DRIVE TRAIN
Transmission Five-speed with reverse
Driveline O-ring-sealed chain
CHASSIS/ SUSPENSION/ BRAKES
Front Suspension Independent double-wishbone with Showa shocks, five-position spring-preload adjustability; 8.2-inch travel
Rear Suspension Pro-Link fully adjustable single Showa shock; 9.1-inch travel
Front Brakes Dual hydraulic 174.0mm discs
Rear Brake Single 220.0mm disc
Front Tire 22 x 7-10 knobby radial
Rear Tire 20 x 10-9 knobby radial
DIMENSIONS
Length 72.2 inches
Width 45.3 inches
Height 43.7 inches
Seat Height 31.9 inches
Ground Clearance 4.3 inches
Wheelbase 48.4 inches
Turning Radius 10.5 feet
Dry Weight 386 pounds
Fuel Capacity 2.6 gallons, including 0.4-gallon reserve
OTHER
Colors Red, Yellow
Model ID TRX400EX
Honda.com
©2004 American Honda Motor Co., Inc. - Motorcycle Division
Privacy Policy | Terms of Use | Trademarks
Back to: 2005 Preview
Select a Model: CBR600RR CRF450X VTX1800F FourTrax Foreman Rubicon GPScape FourTrax Foreman 4X4 ES FourTrax Recon ES TRX400EX Big Ruckus AquaTrax F-12X GPScape Gold Wing
WHERE is the 650EX/R and the new 250 4x4? It won't even allow me to look at anything else but the 400EX. Says the 2005 Model Preview page is "unavailable." What the hell......RedGoblin is getting frustrated......
man i really hope they have a 650ex or something like it.The 400ex is alot better now with reverse and stuff,but why in the hell did they use 450r plastics and headlights,don't know about ya'll but that sucks,they should have redesigned the plastic big time.
Originally posted by: RedGoblin
Actually, I would have been even happier if they had not even touched the plastic, but added a radiator.
i didnt see a 650 either... crap! i thought this was going to be the year!!!
but, the 400ex really doesnt look that bad with the 450r nose. reverse was a smart move. the msrp went up $500, though.
i see the crf450x made it- which means e-start is not too far away from the trx450r and maybe
( i dont know yet) adapable to existing 450Rs. those of you that like to kick, hey, more power to you. but the bike would be more complete with it, IMO.
recon got restyled as with the rubicon and foreman. they got 'suv' styling and some other goodies.
