Starting a Honda in gear
Old Aug 23, 2000 | 03:25 PM
madmax's Avatar
Anyone know how to make your Honda start in gear, Maybe pull the plug on a sensor or make a minor wiring change. I know it can be done because you can buy a special switch to do just that.
(I am to cheap to spend the $60-$80 for the switch At ATV Charley's) So if someone out there knows How, Can you please let me know I am interested in doing this on a Rancher
Old Aug 23, 2000 | 03:42 PM
DrRod's Avatar
Greetings,
You might want to try a search on this -- it has been discussed in here before. A former participant, Gordon Banks, provided a detailed how-to post on this, so you might try to find it as well.
Old Aug 24, 2000 | 07:22 AM
sibbs's Avatar
I installed a start-in-gear switch on my Honda. There's a green wire w/red tracer that runs into your starter solonoid. Tap into that wire and run it to a grounded switch. I used a doorbell button from a hardware store. If you search this forum it's been explained in further detail many times.
Old Aug 25, 2000 | 02:15 AM
demp223's Avatar
There is an even easier way.On the side of your clutch perch is a small switch with two wires.disconnect the wires from switch and reconnect them to each other.This basically makes the starter think that the clutch is pulled in when its not and will now start when in gear.Keep in mind that this is bypassing a safety feature so be careful.Cost-10 minutes
Old Aug 25, 2000 | 02:38 AM
Foreman4x4's Avatar
The only problem with the above post is that the Rancher doesn't have a clutch. If you do figure out how to make your Rancher start in gear let us know. I'd like to be able to start my Foreman in gear.
Old Aug 25, 2000 | 10:54 AM
ATV_MAN's Avatar
I just pull the back-up starter cord sometimes when it's in gear.
Old Aug 25, 2000 | 11:04 PM
250rampage's Avatar
pulling the recoil start works in gear? too bad I'm lazy
Old Aug 26, 2000 | 12:12 AM
cartman308's Avatar
i heard that
neilbedwell
Nov 10, 2018 11:02 AM
HondaR24
Jul 23, 2015 11:22 AM
02Chevrolet
1) Engine problems..
Jun 23, 2015 12:12 AM
1000gade
May 27, 2015 12:37 PM
lovinhonda
Jan 25, 2000 09:17 PM
