My 650 won't stay running
Old Sep 13, 2004 | 04:01 PM
btown's Avatar
Default My 650 won't stay running
I am new to the forum and have a problem. I run my 650 for a few minutes, then it seems to run out of gas. I can't restart it untill it sits for a while. Help!! anyone had this problem?
Old Sep 13, 2004 | 04:23 PM
newbeatle's Avatar
you can try unscrewing the gas cap... if it continues to run like normal, with the cap off, then likely your tank vent line is plugged... if it continues to die, then it is likely the fuel pump / regulator, that is inside the gas tank... I believe there is a prefilter on the fuel pump pick up, but your tank would have to be pretty nasty, for that to be a problem... BTW... welcome to the forums...
Old Sep 13, 2004 | 04:34 PM
rivermud's Avatar
One other thing to check would be the fuel shutoff valve, some have said It gets clogged or O ring twisted inside the valve.
whitty
67
Feb 24, 2021 02:52 PM
MikeyBoyesq
Nov 27, 2020 02:44 PM
Dame0927
Oct 29, 2015 10:13 PM
jayking232003
Jun 9, 2015 02:54 PM
blaze_master
May 26, 2015 11:18 AM
