Tie Rods for 400EX???
Old Aug 24, 2000 | 03:13 PM
VWVR6's Avatar
A buddy of mine bent his stock tie rods racing last sunday. My questions is, are there any heavy duty (aftermarket type) tie rods available. If so, where at...
Thanks!
Eric
Old Aug 25, 2000 | 08:34 PM
Motorhead's Avatar
Just pick up four or five stock ones from your Honda dealer, they're only five bucks each.
Old Aug 25, 2000 | 11:53 PM
tprender's Avatar
You will find that Honda saved some money by making some of the parts for the 400 not as good as they are on the 250R. The tie rods might cost only $5, but they are not the same. After bending one on a 400, I compared a new one to and old 250R tie rod. The R tie rod is about 3/8 in longer, but the diameter of the rod on the 250R is much larger. I now have R one's on my 400. They might cost more but they don't bend as quick. The best way to buy them, is to buy a complete set with ball joints and tie rods. Leager does make some stronger tie rods, but I don't know the cost.
Old Aug 26, 2000 | 01:29 PM
Motorhead's Avatar
Personally, I'd rather stay with the weaker tie-rods. If you take the extreme case, and get the strongest tie rod possible, that just means something else (probably more expensive) has to give/bend/break when you wreck. Keep your weakest link the easiest/cheapest to replace.
Old Aug 26, 2000 | 11:03 PM
VWVR6's Avatar
Thanks for the replys. That does make sense. Let the weaker link be a $5 part rather than something else. We havent priced the stock ones before...did not know they were that cheap. I will have a few in my spare/extra parts box.
Eric
Old Aug 28, 2000 | 10:37 PM
tprender's Avatar
One of our riders went though 12 400 tie rods and dnf about 9 races with the stock tie rods. This spring he switched to the R tie rods and he has not bent any and has not dnf any more races with frond end problems. In the long run the R tie rods will cost less if it helps you finish a race.
Old Mar 18, 2020 | 07:20 PM
evyn.samples@stu.daviess.kyschools.'s Avatar
Thanks!
Eric
there is some available on partzilla for about $120
Old Mar 18, 2020 | 07:23 PM
there not that cheap trust me there about 30 bucks a pop
Old Mar 19, 2020 | 03:23 AM
The above posts are 20 years old, prices will have changed since then.
exmotocrosser
Sep 13, 2019 06:12 AM
XxS0ccerstarxX
Sep 24, 2015 11:53 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
