Non O-ring chain?
I apparently thought I was buying an O-ring chain from rocky mountain...but it isn't. It's an RK 520 motorcycle chain. Can I run this on my banshee? Is it safe? What are the consequences of using it?
Thanks,
jason
Thanks,
jason
I think I would contact Rocky Mtn & inquire whether the pitch on your c/s sprocket is designed to match whatever that chain is designed for. Normally they would ask you what machine you plan to use the chain on. If you told them, then it is apparently just a standard chain, meaning it will require regular lubing, unlike an o-ring type.
The reason this type of chain wears out faster, if in fact they do, is not necessarily because of the design, but because of improper and/or infrequent lubrication.
mrtidy
Feb 3, 2016 05:00 PM
kbazzy
Sep 26, 2015 11:26 AM
