how to clean the air filter
Old Sep 19, 2004 | 06:34 PM
coolguy8769's Avatar
Default how to clean the air filter
What would be the best way to clean the air filter
Old Sep 19, 2004 | 08:50 PM
maddog56's Avatar
I've been known to use gasoline, but it will eat away your filter after awhile. You can buy filter cleaner at most parts shops and dealerships.
Old Sep 19, 2004 | 09:36 PM
hondabuster's Avatar
You can buy solvent or mineral spirits at hardware stores, and after getting the oil out of the filter, wash in soapy water to remove the solvent. Let it air dry and then oil it up.
Old Sep 19, 2004 | 09:41 PM
pinheadedjoker's Avatar
tHE BEST way is to go to a parts store. and get a k/n filter recharger kit for 10 bcuks comes with oil and cleaner. really easy and self explanitory.
Old Sep 19, 2004 | 10:02 PM
BALDMIKE's Avatar
Clean filter in small container of gasoline, be careful ringing out the filter as not to tear the filter, let it air dry when clean and then oil it up like a cutie at the nudie bar.......
Old Sep 19, 2004 | 10:15 PM
iweb's Avatar
Does the K&N stuff work ok on a stock Raptor filter?
Old Sep 19, 2004 | 10:47 PM
sixsixT's Avatar
That's the way I do it. Don't leave the mineral spirits on it very long thou.
Old Sep 20, 2004 | 12:44 AM
heatseeker8's Avatar
I simply use warm soapy water..thats all you need...gasoline/mineral spirits will stretch the foam out and less elasticity..also pick up some filter oil..PJ1 is my oil of choice.
Old Sep 20, 2004 | 03:06 AM
Starky's Avatar
I clean mine in a coffee can with gas. As long as you don't let it soak in the gas and wash it immediatly with Dawn dish soap and warm water it will last a long time. Just remember NEVER to twist it to ring it out. Just squeeze all the gas and oil out then wash it a couple times with the soap and water. Let it air dry completely before you use a good quality FILTER OIL. It's best to have two filters so one can dry while you put the other in and ride.
Old Sep 20, 2004 | 01:25 PM
Gwinnwarrior's Avatar
wal mart sells carb/choke cleaner in aerosol cans. thats what i use. ive found that gas adds a little bit to the air when it goes through and makes it run richer for a while. prolly just my old warrior though. they are all wasy to clean.
COFatboy
May 2, 2020 12:06 AM
cody500ho
14
Aug 14, 2015 05:03 PM
bpegram84
Jul 22, 2015 08:15 AM
bpegram84
Jul 22, 2015 08:12 AM
Aitch
Jul 21, 2015 09:40 PM
