fuel tank/line fittings 400 Scrammy
Old Sep 21, 2004 | 04:33 AM
jimmypsp700's Avatar
Default fuel tank/line fittings 400 Scrammy
What sealant (RTV, etc. ?) do you use for the 90 degree brass fuel line fittings that screw into the bottom of the plastic gas tank. They are leaking, I first replaced the fuel lines that went to the fuel valve (petcock) but that wasn't the culprit. I have heard conflicting info at the Auto stores from soap to Teflon thread tape to certain Permatex RTV sealants (my first thought Black, Blue, Ultra, # 2?) which all do not hold up to gasoline.
Thanks, any info or past experience would be helpful.[img]i/expressions/face-icon-small-smile.gif[/img]
Old Sep 21, 2004 | 06:54 AM
fishslab's Avatar
I would use thread tape or pipe dope for fuel service. We use both on our pipeline equip. here at work and both do very well.
Old Sep 21, 2004 | 08:50 AM
StrayKat's Avatar
I had the same problem with my o3' 600. I had to take the tank off and replace all the metal foil under the tank, it was saturated with gas. I bought a tibe of sealeant at the dealer that worked well, it was about $18.00 a tube. The RTV does not work.... The new bikes are redignes, this was another polaris slip up..... great!!
Old Sep 22, 2004 | 02:38 AM
I ended up using teflon tape and so far so good. I tested some by soaking it in some gas to see if it held up and it did.
bradco
Aug 21, 2015 08:11 PM
Aitch
Jul 21, 2015 09:40 PM
Ask the Editor
12
Jul 21, 2015 06:57 AM
Mikea1978
Jul 4, 2015 12:37 PM
