Removing drive clutch?
Old Sep 24, 2004 | 02:07 AM
samwe's Avatar
Default Removing drive clutch?
Do you need a special tool to remove the drive clucth?
I bought a '95 scrambler that had a broken cylinder and it was removed.
I want to pull the whole engine and put it out of the weather until it gets rebuilt.
I noticed there is water in the crankcase!!!
Thanks.
Old Sep 24, 2004 | 02:31 AM
BigBadScrambler's Avatar
Yes. You need a primary clutch puller. HPD sells them. Water in the crankcase means your counter balance seals are shot
Old Sep 24, 2004 | 09:27 AM
lancems007's Avatar
The tool that HPD sells is really nothing more than a hardened steel bolt with the threads turned down on the ends. Don't mess around though and just buy one from them!
Old Sep 24, 2004 | 01:35 PM
samwe's Avatar
I will check with a local dealer. Shipping is expensive, or slow, and I need to get that engine out before the water freezes up.
I think the water is there because it rained alot and the lower end is sitting there with not much to cover it other then the body.
Old Sep 24, 2004 | 02:21 PM
scramblered's Avatar
polaris clutch puller,your local polaris dealer must have one in stock.
remove drive clutch bolt then screw in the puller til the clutch
come out,depending on shaft it can be hard to throw it out but
it will come.
Old Sep 24, 2004 | 02:36 PM
lancems007's Avatar
It is a ton easier to get it out with an impact wrench too. Otherwise, alot of times you're left just spinning the motor over with a regular socket.
Old Sep 24, 2004 | 09:03 PM
1fastpolaris's Avatar
You can get water in your crank case if you don't drain the water from the radiator by disconnecting the hose top and bottom before you pull the head and cylinder. If this is a 2 stoke.....I just made my own puller by using a 3/8 rod and a bolt
ghost civic
Jan 15, 2020 07:43 AM
ghost civic
Jul 15, 2015 10:48 PM
clsharky
Jul 13, 2015 02:07 PM
tporath
Jul 11, 2015 12:31 PM
200es
Jul 10, 2015 09:09 AM
