i'm thinking about the HPD Trail pipe
Old Sep 25, 2004 | 07:30 PM
DGScrambler400's Avatar
Default i'm thinking about the HPD Trail pipe
i have a question about it tho..im not willing to spend 179$$ on a full clutch kit, so will i be able to just buy new primary and secondary clutch springs and get close to the same effect out of the pipe? I dont want much higher engagment than stock, and i still want to be able to do slow technical riding, but also good high performance riding. is that possible?
Also, will my stock piston be able to handle all of the mods i have, plus the pipe? Thanks
Old Sep 25, 2004 | 10:19 PM
2manytoys's Avatar
The stock piston will handle it just fine. All you need is the standard aggressive clutch kit with the pipe. It has the springs,weights and shims. The only difference with the more expensive one is the helix. The trail pipe is a great pipe.
Old Sep 26, 2004 | 01:30 AM
yammaslamma's Avatar
i have the AAEN torquer pipe...basically same thing as HPD trail pipe and i havent had mine clutched yet but i still can tell a different with how mine runs....it pulls harder in the mid and it revs a noticeable amount quicker..
Old Sep 26, 2004 | 11:33 AM
radblazer400's Avatar
I have the trail pipe and the $99 dollar clutch kit (primary, secondary springs and weights). It works great together.
Old Sep 26, 2004 | 10:58 PM
scrambler123's Avatar
if you get a trail pipe you could get a red/yellow primary and violet secondary and use the stock weights and helix and get good results.
Old Sep 27, 2004 | 04:28 AM
jimmypsp700's Avatar
rick sells the trail pipe ($190) and a clutch kit ($90) without the helix. or you could just change the primary spring one heavier.
Ean
Dec 19, 2022 08:48 AM
Frisky2050
Apr 9, 2020 11:19 AM
coldnorthpol
Jul 14, 2015 11:22 PM
yambam13
Jul 4, 2015 01:49 PM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
