Re-build 90 trailboss 250 2-stroke. 2x4
Old Sep 26, 2004 | 10:05 PM
MrDumass's Avatar
Super Quad Patrol
Athens Archery Field Staff
Best lunch hour ever!
Default Re-build 90 trailboss 250 2-stroke. 2x4
Few questions....How hard is it to rebuild this 250? I have the manuel on it. Also I want to bypass the oil pump, as this seems to be the reason I've got a blown motor, what gas to oil ratio should I use? All suggestions greatly appreciated!
Old Sep 28, 2004 | 06:50 PM
MrDumass's Avatar
Super Quad Patrol
No-one can answer this post????
Old Sep 28, 2004 | 06:52 PM
tbsleeper's Avatar
bore, get a wiseco, get a single throttle cable, get a oil injector block off, mix at 40/1
Old Sep 28, 2004 | 08:19 PM
Bradracer18's Avatar
agree 100% with ^^^^
Old Sep 29, 2004 | 06:24 PM
MrDumass's Avatar
Super Quad Patrol
ok Where do I get an oil injection block off and what is a single throttle cable? Do I need to just buy the wiseco top end re-build? Man I'am dum... This is my first rebuild! Think I can do-it? Also I think it has been bored before, just waiting until I get it tore apart to tell. One las question.. Can I leave the motor in the frame to do this?
Old Oct 4, 2004 | 11:08 AM
MrDumass's Avatar
Super Quad Patrol
I cant get any info from you guys in the Polaris forum! If I asked about a different quad in a different forum, I would get a ton of info.... Thanks a friggin lot!
Old Oct 4, 2004 | 11:34 AM
RickRitter's Avatar
Your 250 blazer is a pretty straight forward rebuild . There are very few moving parts in that machine . If you have the crank rebuilt , install new main bearings , and get a fresh bore and piston kit you have a brand new engine .
The oil block off and cable costs about $41 and is easy to find .
Rick
Old Oct 4, 2004 | 01:41 PM
scootergptx's Avatar
Supersock
Hired Gun!
This is the Polaris forum, on the weekends we're out riding, not sitting at home. Be patient and you'll get (more) answers. If your going to do a complete tear down, yes it will be easier with it out of the frame. Rick can probrably get the parts you need and the advice you'll want, give him a call.
Old Oct 5, 2004 | 11:55 AM
MrDumass's Avatar
Super Quad Patrol
Thanks for the info! Sorry for being an impacient a-hole. I think I can get-r-dun! I just need to know a good place to order the parts I need.
Old Oct 5, 2004 | 12:40 PM
davesp's Avatar
Go to www.partsland.com. Run a 40:1 mix when broke in. I'd run a 32:1 mix during the break-in period.
