Powdercoating A-arms
Old Sep 28, 2004 | 09:18 PM
Troyer23J's Avatar
Default Powdercoating A-arms
How do I get the arms powdercoated when I can't take out the ball joints?
Old Sep 28, 2004 | 09:44 PM
Bradracer18's Avatar
You can take them out, I think they are usually pressed in there though......kind of a pain in the @ss though......You have to press them in too......
Old Sep 28, 2004 | 10:36 PM
Troyer23J's Avatar
do they have to be taken out? Or can they stay in. What about that heat resistant tape, i have read that can prevent things from getting too hot.
Old Sep 29, 2004 | 09:46 AM
Troyer23J's Avatar
bump
Old Sep 29, 2004 | 10:31 AM
CED's Avatar
CED
If you are talkin about the strut housings,i just did mine.I didn't remove the ball joint.There is no plastic or teflon in there so you will be ok.I just greased the crap out of em when i got them back.The ball joint can be a real pain to remove,that's why i left them in there.
Old Sep 29, 2004 | 04:32 PM
Troyer23J's Avatar
Well, I am talking about on my 250R a-arms, the bottom ball joints stay in, i guess we'll try it.
Old Sep 29, 2004 | 05:34 PM
CED's Avatar
CED
Oh ok,i think they have a plastic bushing inside.Be careful.
Old Sep 29, 2004 | 05:55 PM
WISTECH's Avatar
Stupid Honda. If you carefully pry the boots off and flush the grease out of the joint. It takes a while. All they have to do is sandblast and tape off the joint area before coating. Then work grease back in and reinstall the boots. Not to difficult if your careful.
Old Sep 29, 2004 | 06:31 PM
Troyer23J's Avatar
The boots are like glued or something, I can't get them off without them trying to rip...
Any thoughts?
Old Sep 29, 2004 | 06:52 PM
WISTECH's Avatar
They have a metal ring formed into the end of the boot that fits over a lip on the joint. You have to use something sharp like a putty knife or very thin screwdriver to force between them to separate. Tap with a hammer on the knife and work around in a circle .Dont cut the boot or you will need new ones which might not be available anymore.
