2 stroke problem
Old Sep 29, 2004 | 12:03 AM
HawgFan's Avatar
Default 2 stroke problem
i have a 93 Polaris 350 and need to rebuild the topend, there is no machine shop within 150miles of my home, does anyone know a reliable shop where i can send it to get it bored? any suggestions on the best lace and best kind of piston to get? any help would be appreciated.
Old Sep 29, 2004 | 12:53 AM
TJCINC's Avatar
ALOT OF YOUR LOCAL AUTO PARTS HOUSES HAVE A MACHINE SHOP. IF YOU HAVE TO REPLACE YOUR PISTON GO WITH A WISECO PISTON. NOT THE STOCK. I DONT KNOW WHERE YOU LIVE SO I CANT HELP WITH EXACT PLACE TO TAKE IT.
Old Sep 29, 2004 | 01:08 AM
Bradracer18's Avatar
You can take it to a local NAPA autoparts shop, or send it off to doug nicholas at nicholas cycle to get it done.......his number is on his stie(www.nicholascycle.com)........Also go with a wiseco like he said.....much more reliable
Old Sep 29, 2004 | 12:34 PM
textrout's Avatar
Well, I"m having the same problem, and the polaris dealer quote me $780 for rebuilding the top end. What do you think about this price, and is it worth putting a thousand bucks in this bike? It's high milage, worn a lot, but mostly has run well. Any opinions? Also how much would a wiseco piston add to the cost?
Thanks!
Textrout
Old Sep 29, 2004 | 01:56 PM
davesp's Avatar
I have seen Wiseco piston kits go for as low as $69.00 to $105.00
Old Sep 29, 2004 | 04:37 PM
GST97's Avatar
$780 to rebuild a 2stroke is ridiculous. $780 should get you a BRAND NEW cylinder and a wiseco and a couple hundred dollars leftover [img]i/expressions/face-icon-small-wink.gif[/img]
You could send it out to RCR (www.rittercycle.com), its around 35 to bore/hone out the cylinder and 100 for a wiseco piston. So for $150 including shipping, the top end will be ready to go.
Add in another 15 or so if you need a new upper needle bearing, and 15-30 for a gasket set.
It is very easy to disassemble and reassemble yourself, just make sure to lube everything up well with 2stroke oil.
-Chris
kelleycully
Sep 15, 2016 02:57 AM
SDR-II
Sep 29, 2015 01:06 AM
NatePerz
Jul 27, 2015 03:27 AM
ghost3
Jul 19, 2015 08:46 PM
