Hozed - In The Process Of A Mental Meltdown
Old Sep 29, 2004 | 09:02 PM
Hozed's Avatar
Default Hozed - In The Process Of A Metal Meltdown
THE PILE OF **** STILL HAS 90 LBS OF COMPRESSION!!!
its gotta be something with my auto decompression thingy... thats all i can think of.
Old Sep 29, 2004 | 09:15 PM
Sceiks's Avatar
Default Hozed - In The Process Of A Mental Meltdown
Must be the yamaha......good luck
Old Sep 29, 2004 | 09:22 PM
GE4x4's Avatar
That stinks. How are the valves? Are they seated right? Maybe some carbon build-up on the seating surface. Weak or broken valve springs. So many different things can give a poor compression. Spark plug tight. I hope it's that simple. Keep your head high, it's most likly something simple. [img]i/expressions/face-icon-small-smile.gif[/img]
Old Sep 29, 2004 | 09:30 PM
Hozed's Avatar
valves are good... its gotta be simple... ive done all the hard stuff!!!
Old Sep 30, 2004 | 01:33 AM
EAB's Avatar
EAB
Do you have the ability to inject compressed air through the spark plug hole? Then see where its leaking out.
Old Sep 30, 2004 | 01:39 AM
fishslab's Avatar
Does it hold it or will it lose the 90lbs too?
Old Sep 30, 2004 | 06:58 AM
Hozed's Avatar
not sure how to tell.
Old Sep 30, 2004 | 08:33 AM
Flynbryan's Avatar
Its the decompression "thingy" Hozed. I read about that somewhere before. I'm uncertain how you by pass it, but I believe thats your issue. All I can say is ask around maybe even a dealership if you know someone in the maintnance department and see how you get around it.
Old Sep 30, 2004 | 10:11 AM
RickRitter's Avatar
Hozed ,
I took a YFZ 450 apart and found 2 broken valve springs . I haven't heard of this except on one I saw at the shop . Might be worth a look .
Rick Ritter
Old Sep 30, 2004 | 05:00 PM
Hozed's Avatar
i just got off the phone with my dealer... i am good friends with them... and they been trying to help me out... they also think my last option is the decompression thingy... i dunno if i can by pass it though... it might start hard then.
rick... dont scare me!!!! all the valves seems ok when i checked them for clearance... a broken spring would mess that up i think... but ill take a look... thanks.
Customer Service #1
May 15, 2020 08:46 AM
Beeline08
Nov 11, 2016 04:00 PM
salixair
Nov 3, 2015 08:25 AM
Nosniborpapa
Sep 19, 2015 07:07 PM
Elkaholic
Sep 6, 2015 02:44 PM
