carb leaking gas from vent line..
Old Sep 30, 2004 | 05:46 PM
Jayblazer's Avatar
Default carb leaking gas from vent line..
the carb is leaking gas out of the vent line right under the fuel line it only happens when the quad is running so what in the heck could be causing this??
Btw i did just get done messing with the jetting so could that have something to do with it???
Old Sep 30, 2004 | 06:07 PM
Tpsycho's Avatar
My Bomb Busa is done now and WOW what a rush this thing is scary fast. I love it
Sounds to me like your floats are out of adjustment you could have bent the float tab that goes to your needle valve and seat on your fuel inlet or your needle and seat are worn out I would try adjusting your floats first if that does not do the trick replace the needle and seat.
Old Sep 30, 2004 | 06:39 PM
Jayblazer's Avatar
what do you mean adjust your floats??? Also i never opened the carb i just opened the small bowl on the bottom to get at the main jet.. also if it was a stuck float wouldent it leak all the time??
Old Sep 30, 2004 | 07:12 PM
Tpsycho's Avatar
I do not think the float is stuck or it would leak all of the time. I think your floats are out of adjustment . When gas enters your float bowl the floats float on top of the fuel and the tab located at the base of the floats rises up and closes off the fuel inlet needle and seat. If the tab is bent down to close to the float the fuel will leave the bowl thrue your overflow tube before the floats can turn it off. I think a simple float adjustment would fix your problem.
GregM
Mar 6, 2018 06:53 AM
SDR-II
Sep 29, 2015 01:06 AM
Captjay
Jul 23, 2015 12:33 PM
Unzzy66
Jul 11, 2015 10:01 PM
rcappie4
Jul 10, 2015 04:54 PM
