eating up piston.
Old Sep 30, 2004 | 08:45 PM
crazyray's Avatar
Default eating up piston.
I have a 2000 blaster. ( 200 cc ) This is the 2nd piston now that the shirts are gettin all broken up into little peices. It was running great and now with about 10 houres on it the piston skirts are all blown apart. What's happening ????? HELP
Old Sep 30, 2004 | 09:11 PM
FdaDOT200's Avatar
did you bore your cylinder?? cause if it did it the first time you could have just blown the top end and then you have to or should bore the cylinder.
Old Oct 1, 2004 | 06:14 AM
crazyray's Avatar
Everything is stock. And the cyl. is clean with no markes in it. The last one I put in, I replaced the piston, ( weisco ) wrist pin, clips and bearing.
Old Oct 11, 2004 | 10:26 AM
FdaDOT200's Avatar
i did the same thing, the reason i blew my top end was becasue of the wrong plug and it ran too hot and shattered the piston. I think i have a B9ES in it now, it a NGK-R. Also you should at least get it honned..
Old Oct 11, 2004 | 12:38 PM
MasterRaptor's Avatar
Did you check the piston clearance? If your clearance is out of spec, piston slap can cause the skirt to break.
MikeyBoyesq
Sep 7, 2015 10:44 PM
Hankey Pankey
Jul 31, 2015 05:50 PM
Hankey Pankey
Technical and How-To Articles
Jul 29, 2015 10:57 PM
Holyman
Feb 6, 2001 06:25 PM
92LT
Jun 20, 2000 08:58 PM
