what kind of oil are you using? 03 500
Old Oct 1, 2004 | 02:47 PM
want2Bmuddy's Avatar
Default what kind of oil are you using? 03 500
What oil do you recommend? I have 10-40 in now and wonder after break-in if I should change to 5-30? whats your thoughts btwn 5 and 10 weight oil? I heard that 5-30 is better for lubracation and better for parts? The temp chart is about the same, the 5-30 for cooler weather & 10-40 for hotter weather. The climate that I will be riding in falls btwn both oil temps. Does one lubracate better than the other? Thanks!!
Old Oct 2, 2004 | 08:55 PM
alcoff95's Avatar
I use Amsoil's 0w-40 synthetic. Good all year round, hot or cold. AC also has a 0w-40 synthetic.
I would only use 5w-30 if you regularly ride in very cold temps.
If your 500 is a manual, make sure whatever oil you use is wet clutch compatible.
That's my $.02
Old Oct 2, 2004 | 09:42 PM
CATSKINNER's Avatar
The Arctic Cat 400 and 500 auto's have a wet clutch as well.
Old Oct 6, 2004 | 10:17 AM
garyvegas's Avatar
Amsoil 0W-40 four stroke is the way to go.
Old Oct 6, 2004 | 05:17 PM
freetrapper's Avatar
I use Arctic Cats 0w-40 All season Synthetic and it seems to work great.........
XxS0ccerstarxX
Sep 24, 2015 11:53 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
Alex G.
Sep 16, 2015 12:13 PM
Ridgerunner665
Sep 15, 2015 01:20 AM
