Starting on Raptor
Oh yeah, air up your tires and they will spin more. If you are on pavement, you arent going to get very far with a stock length swingarm. You can get a 4.5 inch swingarm extension for about 250 bucks I believe, much cheaper than a new swingarm and easier to install.
practice is the only cheap advise. lean forward, not too much gas and feather that clutch til u get going, even with the rap in a drag, if once u get going, and u punch it it will still fly up on you, u need to learn and practice to be smooth but quick at the same time, try 2nd gera starts also
i would change the sprockets, their the cheapest. but it kinda destroys the point of gearing down to start ing second? why do you want to start in second anyway. get some motor work done so you have the power to start in second, or get a swingarm, or else you burn up your clutch.
