Is there an aftermarket suspension kit for a 185s 3wheeler
is there an aftermarket suspension kit for my 185s 3 wheeler , if there is could you give me a web site w/it in there and if not can i make an front a rear suspenson for it?
Yes, its called new tires.
Most of your suspension is the huge radials. You wont get much out of a suspension change, assuming you have a suspension under there to begin with.
haha i have holeshots on it i dont have susp. under it at all , i was wondering if there is b/c heres one w/ susp. on it http://cgi.ebay.com/ebaymotors/ws/eB...MakeTrack=true go to it and ull see....
If you can find a 200x with a blown motor you could put your 185 engine in it, it will bolt right in. Thats what I did with mine a few years ago. It will work much better than trying to weld some suspension parts to your stock frame.
you will need the 200x intake manifold that goes between the carb and the motor for the carb to mount up right. (infact I used the 200x carb) and you will also need the stock 200x exhaust pipe. Also my need some of the engine mounting brackets from the 200x, I cant remember which brackets I used.
