How tight should the chain be?
Old Oct 18, 2004 | 05:52 PM
new2atv's Avatar
Default How tight should the chain be?
I have an '01 Xplorer 400 4x4 and the rear chain is fairly loose on it. How tight should it actually be? Do I leave a little play? Get it snug with it sitting with no extra weight? I've read different posts but I'm still not quite sure. Any insight is appreciated.
Thanks.
Old Oct 18, 2004 | 05:56 PM
maddog56's Avatar
I leave about 3/8 to a 1/2 inch of slack in the chain with no rider. I know that polaris has some different swingarm setups, so you may have to adjust that figure depending on which design you have. I dont remember what the xplorer rear end looks like.
Old Oct 18, 2004 | 09:05 PM
Snowwolfe's Avatar
You want to be able to compress the suspension and still have just a tad of slackness. If you adjust the chaint to tight and you compress the suspension the chain is the first thing to snap.
Old Oct 26, 2004 | 10:49 AM
new2atv's Avatar
Thanks for the recommendations.
Old Oct 26, 2004 | 12:26 PM
Bradracer18's Avatar
Take a ratchet strap around the bumper and axle, strap it down to the max you will ever compress it.......then give just a little slack in there(max 1/4").......
Old Oct 26, 2004 | 12:55 PM
Bing's Avatar
Super Quad Patrol
Smokes meat all the time!
i believe an 01 explorer has the concentric rear end (chain/countershaft and the swingarm pivot on the same axis)
you shouldnt need to strap anything because the chain tension remains constant throughout the motion of the swingarm
Old Oct 26, 2004 | 01:00 PM
yep you are correct Bing........I guess I didn't read it very carefully, I didn't see it said 01............anyways......now you know how to do it to an older model.....lol.......
Thanks again Bing
Old Oct 26, 2004 | 01:09 PM
Bing's Avatar
Super Quad Patrol
it would have produced the same result
just thought id save him the extra strap trouble[img]i/expressions/face-icon-small-smile.gif[/img]
Old Oct 26, 2004 | 05:44 PM
new2atv's Avatar
Ok....I just want to make sure I have my information straight. I should be able to tighten up the chain, but leaving a little bit of slack, without having to compress the suspension?
Old Oct 26, 2004 | 06:43 PM
yes you are correct, either way is fine, but if you compress the suspension(on the newer models) it stays at the same angle and tightness as if it were compressed..."concentric"...................
