were is drain plug for transmission 325 magnum polaris 2000
Old Oct 18, 2004 | 11:45 PM
kipseager7503's Avatar
Default were is drain plug for transmission 325 magnum polaris 2000
[img]i/expressions/face-icon-small-cool.gif[/img][img]i/expressions/face-icon-small-confused.gif[/img] Can any one tell me were the drain plug is for the transmission fluid on a 325 Magnum Polaris 2000 I just can't seem to find it.Either I'm blind to it or I'm just not looking in the right place. Thanks Alot
Old Oct 19, 2004 | 07:48 AM
ftwflh's Avatar
On the bottom left hand side of the tranny you will see a long bolt jammed up against the frame.Losen this bold(screw it in)and the part that you screw it into is the drain bolt.Once the bolt is in enough you can take the drain plug out.
Old Oct 19, 2004 | 12:50 PM
[img]i/expressions/face-icon-small-smile.gif[/img]Hi thanks for the info. I had to remove the skid plate[img]i/expressions/face-icon-small-blush.gif[/img] then I found the drain plug... facing the front of the atv 3nd one from the left. anyways I would like to thank you for your input is is greatly app. thanks again
Kipseager7503
green giant
Jul 13, 2017 12:07 PM
WilliamBos
Sep 30, 2015 08:08 AM
DOAinNY
Jun 11, 2015 10:34 PM
wbfjim
Jun 8, 2015 06:20 PM
