need ideas plug fouling
Old Oct 20, 2004 | 10:29 PM
GoldProspector's Avatar
Default need ideas plug fouling
working with an 03 p650 front plug keeps fouling
Old Oct 21, 2004 | 12:26 AM
PrairieDude's Avatar
Sounds like the front carb is running rich. Try adjusting the air/fuel screw on the front carb. The stock setting is 2 1/4 turns out (counterclockwise). Close it up (turn clockwise) to make it leaner. Another cause may be that your front carb choke may be stuck open due to a weak choke spring. Replacement spring part # is 92081-1720. After tweeking the carbs, resync the carbs with a mercury carb tuner guage. I have a Carbtune model. Motion Pro also makes a good one. Anyway, start with adjusting the air/fuel screw.
marshel
Jul 25, 2015 07:17 PM
chammerbeck
Jul 17, 2015 08:06 AM
Scottma518
Jul 16, 2015 09:19 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
D-Hagz
Jul 4, 2015 02:19 AM
