Virus , or stupidity, NEED HELP!!! I HAVE HOMEWORK TO DO!!!!!!!!!!!!!
Old Oct 21, 2004 | 02:12 AM
12em's Avatar
Default Virus , or stupidity, NEED HELP!!! I HAVE HOMEWORK TO DO!!!!!!!!!!!!!
I cant log onto my computer!!!
i dont know if its a virus, or i messed something up.
i get to the login screen and i click my picture to log in, it works, but then instantly it logs off!!! What is wrong?!?!!?
Any help or suggestions would be VERY VERY VERY VERY appreciated.
i have school tomorrow at 6:00 and its 10:00 here now. I have at least 2 hours worth of homework to do on that computer and its due TOMORROW!!!!
please help, i am begging!!!!!!!
btw i just created this account because i couldnt log onto my regular one which is "rem"
Old Oct 21, 2004 | 03:04 AM
Sidewinder500's Avatar
try loggging in, in safe mode. Then if you are running windows xp do a system restore and see if that helps. If you are still having problems after the restore boot up again in safe mode and get on the net and go to trendmicro and do a free online virus scan (house call on their website).
Old Oct 21, 2004 | 08:12 AM
300exRiderJay's Avatar
Well, i know its kind of late, but on my computer(with windows XP), i can access all of my saved stuff from everyone elses log in name. so you can do that until your homework is done, then just fix it when you have some time.
Old Oct 21, 2004 | 11:05 PM
12em's Avatar
the problem is that i can boot up, but not get into windows and access any programs or anything, i am on my mom's computer right now.
Old Oct 22, 2004 | 12:34 AM
Bad times....... sounds like you are going to lose everything unless you are running dual hard drives in your computer and are good enough in MS-DOS to transfer files that you would like to keep to a different hard drive. Then put in a windows disc and format that puppy. Format C:\(enter)
Old Oct 22, 2004 | 01:25 AM
Slinger's Avatar
You sound like you have a Dell with the XP operating system. Just kidding, I had the same thing, log into my account and my desktop would come on but nothing else would run. I went around this with F8 and operating in safe mode. You will probably have to do a total restore with the drivers that came with your computer, later. What program are you trying to use? If it doesn't work in safe mode, just reinstall it(the program) with the appropriate driver disc.
Old Oct 22, 2004 | 03:37 PM
seks69's Avatar
Had the exact same problem 2 days ago. It has something to do with Lava Soft & Ad-Aware.
THIS REALLY WORKS!! (go to bottom of reply for link)
You will have to use your Windows XP CD-ROM and press R to start the Recovery Console.
Next:
cd system32
copy userinit.exe wsaupdater.exe
exit
Remove windows CD and restart. Login with a user that has administrator rights.
Using regedit
HKEY_LOCAL_MACHINE
Software
Microsoft
Windows NT
CurrentVersion
Winlogon
Locate Userinit in the value column, right-click this item, and choose modify.
Replace wsaupdater.exe with userinit.exe
Restart your computer!!!
It sounds like a lot of work but it's not - just follow the instructions and you have your system back...
http://www.lavasofthelp.com/articles...rint/0901.html
Good Luck!!!!
Customer Service #1
May 15, 2020 08:46 AM
Ricardo Covarrubias
Sep 17, 2015 08:28 AM
Ridgerunner665
Sep 15, 2015 01:20 AM
GODsRebel
1) Engine problems..
11
Sep 8, 2015 12:07 AM
Atvnewb88
Aug 13, 2015 06:48 AM
