Sport Quads Discussions on sport quads.
*help with 400ex*
Old Oct 22, 2004 | 11:01 PM
whiteflash1's Avatar
Default *help with 400ex*
i was riding in the mud today and my right grip must have gotten water or mud under it, now the grip itself twists. when i tried to take the grip off by loosening the screw on the end, it didnt seem to loosen. I cant ride to until i get this fixed, so please help!
Old Oct 22, 2004 | 11:24 PM
mucky's Avatar
if you have the cap off the end of the bars we take a air hose and stick it under the grip
to loosen it. twist it off while applying air to it. once removed dry everything and use grip glue to hold it in place
Old Oct 22, 2004 | 11:26 PM
ya but i cant get the cap off, it doesnt seem to just loosen, and what kind of glue
Old Oct 22, 2004 | 11:35 PM
mucky's Avatar
most bike shops have glue for grips. renthal makes it
I had a cap that wouldnt come off so I used vise grips on it and twisted it off
didnt care if I broke it
I took them off and left them off. I put new grips on at the time
Old Oct 27, 2004 | 12:34 PM
Curls's Avatar
I learned a cool trick years ago that has been working real well. After taking your old grip off (you might need to cut it off) I clean the bar real good with brake cleaner. After it is perfectly clean I wet the new grip and the bar with brake cleaner and quickly shove the new grip into place. Brake cleaner evaporates real fast so you've got to be quick. My grips have never loosed or twisted on me using this method. Don't use too much brake cleaner on the grip because the rubber will be dissolved partially by the brake cleaner.
Old Oct 27, 2004 | 12:56 PM
Raptorlegs's Avatar
T Rex Rider
What irritates me is!
Those 6-packs work pretty good.
Heard hair spray works good.
I know soap don't! [img]i/expressions/face-icon-small-mad.gif[/img]
Old Oct 29, 2004 | 02:57 AM
Jibrille's Avatar
I'd just suggest breaking the caps off, buying new grips, then putting them on with those caps.
I don't use glue, I use wire to hold my grips on, that way when they wear out, they're easy to take off.
