tires raptor
Old Oct 24, 2004 | 01:04 AM
dman4quads's Avatar
Default tires raptor
flip front tires over and use washers so valve stem will clear you will need 24 washers and $2.00 it will increase front of raptor buy 2-3 inches per side.
Old Oct 24, 2004 | 05:01 AM
maddog56's Avatar
Just make sure you dont get any air or hit anything hard with that setup.
Old Oct 24, 2004 | 04:57 PM
dman4quads's Avatar
I work in a prototype shop and we take everything to the extream. try it no dif then a wheel spacer alot of companys do not try everything they want it to go to production. The only down fall is trail riding in rocky areas that could damage caliper. onother mod put the fan and radiator inside the frame lightens up the front end.
Old Oct 24, 2004 | 04:58 PM
dman4quads's Avatar
I live in michigan by the ohio line near toledo.
Old Oct 24, 2004 | 08:23 PM
maddog56's Avatar
Well whether you use mass produced wheel spacers or use washers on your own you are still severely weakening the front end. A good tree clip or hard landing and you will be towing it home.
Not sure what your location has to do with anything, but there should be enough tight wooded trails in that area that you would want to be careful at high speeds.
STLyamwar
Jul 25, 2020 04:44 AM
Aug 21, 2015 01:23 PM
suzukiquadrunner1987
Aug 9, 2015 08:45 PM
black_thunder
Jul 22, 2015 06:01 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
