2nd battery
Old Oct 25, 2004 | 02:29 AM
Pushinlimitz's Avatar
Default 2nd battery
im thinking of adding a second battery to my scrammy. has any one done this?
Old Oct 25, 2004 | 02:34 AM
BigBadScrambler's Avatar
Default 2nd battery
Most seem to want to lose the one they got![img]i/expressions/face-icon-small-happy.gif[/img] LOL Any particular reason why?
Old Oct 25, 2004 | 02:45 AM
Default 2nd battery
i guess im differnt then most brother.lol I wanted more power on hand for my winch , you see wen i use my winch to move something like a trailer,or engin stand , (i have a very bad back so i do this alot) my quad idles so it doesnt charge the battery enough,also my starter seems slugish wen its cold,i dont know why. i had it rebilt,and i also replaced the battry. it just seems to have no power most of the time.what do you think?
Old Oct 25, 2004 | 03:10 AM
Default 2nd battery
Ahh. I see now. Well, you can add another battery. You would probably have to make a mount for it somewhere. You also might want to consider having your stator rewound for more output to charge the battery faster.
Old Oct 25, 2004 | 10:07 PM
Default 2nd battery
i was just thinking , how would you test the stator to see if its pushing the power it should???
Old Oct 25, 2004 | 10:13 PM
Snowwolfe's Avatar
Default 2nd battery
Maybe consider adding just a bigger gel battery?
Old Oct 26, 2004 | 12:25 AM
Default 2nd battery
To test the stator output, you need to use a multimeter set on DC volts. Touch the red lead to the positive terminal on the battery and the black lead to the negative lead of the terminal. This is your open circuit battery voltage. It should be 12.4V or more. Now start the machine and raise the engine RPM to 3000-4000 RPM. You should have between 13 and 14.5V DC
Old Oct 26, 2004 | 01:15 AM
Default 2nd battery
oh so its the same as the alternator in a car,makes cents. LOL some times im so dumb[img]i/expressions/face-icon-small-blush.gif[/img]
Old Oct 26, 2004 | 01:19 AM
Default 2nd battery
that may be just the ticket, ill look in to that. it would probably be easyer
Old Oct 27, 2004 | 10:22 PM
Default 2nd battery
i just tested my stator , its not workin at all . i got a grand total of 7.4 volts !!!!! ive never been so exited about something being broken before ! [img]i/expressions/face-icon-small-happy.gif[/img]
