Clutch problems!
Old Oct 26, 2004 | 02:29 PM
Belrog's Avatar
Default Clutch problems!
Hello all!
My SP700 -03 is behaving a little strange. It feels almost like you´re starting on "second gear". When i examined the primary clutch yesterday i noticed a freeplay of 3mm in the clutch. When i rev the engine, the clutch engage, when the engine goes back to idle, the clutch falls back out, but not all the way. I have to wait a few seconds for the clutch to "fall out" the last 3 millimetres.
When i push the clutch towards the engine, there is no resistance the first 3 millimetres.It´s just sliding on the axle
Is this normal?
Could the spring be broken?
Regards from Sweden
Old Oct 26, 2004 | 08:03 PM
ftwflh's Avatar
Sounds like it could be in your secondary clutch.
Old Oct 26, 2004 | 10:40 PM
Krank's Avatar
Sounds like you have to clean the primary. Mine was hesitating going out the same way. After I cleaned it, it worked fine. I had no problem with acceleration though.
skinnyr6
Aug 25, 2023 02:18 AM
clsharky
Jul 13, 2015 02:07 PM
200es
Jul 10, 2015 09:09 AM
coolguy420
Jul 10, 2015 01:17 AM
Wnthunting
Jul 9, 2015 03:02 PM
