Hi compression piston or big bore?
Old Sep 1, 2000 | 07:03 PM
Dom's Avatar
Dom
I run a 16t font sprocket on my 400ex and would like to have more torque in 4t and 5t gear.
I dont now if I should put a hi compression piston and cam ore go with a 440 big bore kit,rev limiter, etc...
Thanks for the reply.
Old Sep 1, 2000 | 07:19 PM
ogre's Avatar
Why not bore out your cylinder (416cc, 426cc, or 440cc) and put in a higher compression piston as well?
ogre
Old Sep 1, 2000 | 07:55 PM
Tree Farmer's Avatar
You're on top of it, ogre! Re-bore requires a new piston anyway!
Tree Farmer
Old Sep 4, 2000 | 05:47 PM
HILLSVILLE69's Avatar
damn 16 tooth whats stock?
Old Sep 4, 2000 | 10:10 PM
GriffsFSR's Avatar
15 tooth is the orignal equipment
Old Sep 5, 2000 | 12:27 AM
Trx-400ex's Avatar
It would be a lot safer to run a 15 tooth sproket with a 41 tooth rear there for you can run the case saver...case saver saved my engine on more then one account...friggen rear bearings
Old Sep 5, 2000 | 09:43 AM
Dom's Avatar
Dom
I Have modify my case saver and run with 16t front sprocket because I need more top speed to run on long gravel road.
Now, is there anyone that can tell me if there is a big difference in the mid to high rev when you put a high compression piston(stock bore) or is it best to put a 440 big bore.Thanks for the reply.
Old Sep 5, 2000 | 02:15 PM
GriffsFSR's Avatar
How did you modify your case saver to run the 16 tooth. I found that you would have to grind it down to being only no exsitence.
Old Sep 5, 2000 | 04:56 PM
Slyder's Avatar
You are going to have a problem finding a 440 piston that does not increase your compression to at least 11:1. The compression increase will definitely benefit your low and midrange. If that is the main place you are looking to gain power (low and midrange), I would not spend the extra money to go to a 440 (requires a new cylinder sleeve).
Old Sep 6, 2000 | 09:36 AM
Dom's Avatar
Dom
To griff, yes I have grind my case saver to fit my 16t front sprocket and buy a new one when I go with the original 15t.
