Brake caliper leaking
Old Sep 1, 2000 | 10:38 PM
mikeslaby's Avatar
My rear brake caliper seems to be leaking. The inside surface on the rotor is coated with a dirt and brake fluid. Anyone had dealt with this.
Old Sep 2, 2000 | 12:24 AM
MudCrazy's Avatar
Mike
You might want to try just tightening the two bolt's that hold it together. Seem one of mine worked it's way loose just a smidge, enough for me to see that the fluid had gone down a little.
Old Sep 2, 2000 | 10:45 AM
CatLance's Avatar
I haven't noticed my calipers leaking, but my master cylinder leaks when I park it with the brakes locked (under pressure). I do have the metal cylinder on my cat & it has leaked enough down on the fender that the brake fluid ate up one of the decals. It does not leak unless locked & I checked the screws holding the top & they are tight. Anyone else seen this? Is there a gasket between the top & cylinder I need to replace? Thanks for any input. Lance
bmark0610
Sep 9, 2015 10:56 AM
bmark0610
ATC 3-Wheelers
Sep 7, 2015 07:48 PM
oliveiracarlos
Sep 7, 2015 03:39 AM
oliveiracarlos
Sep 6, 2015 01:38 PM
