clutch wear
Old Nov 11, 2004 | 06:16 PM
polarisman3's Avatar
Default clutch wear
well i took this clutch apart it is a Comet clutch (off '01 rmk 600) and there is play between the spider and the outer clutch sheeve you know where the buttons are...well the buttons are worn down about 1/32 or a hair more.....the spider has play like i said so is that amount of button wear excepable????? thanks guys...i took it apart cus this is the second spring that it has broke...time to go with a round one instead of square...
Old Nov 11, 2004 | 09:58 PM
Polaris500HO4x4's Avatar
Default clutch wear
get those buttons replaced or it will get expensive
Old Nov 11, 2004 | 10:14 PM
OneBadPolaris440's Avatar
Default clutch wear
well if your clutch is binding the you will need to replace the clutch .... My clutch was binding and it held my performance back alot .... if you look where your spider slides down see if there is any wear in there because if so your clutch is binding and thats not good
Old Nov 11, 2004 | 11:23 PM
Default clutch wear
thanks guys, well yes there is some wear where the buttons slide so i better get new buttons in there and clean the clutch up....so there should nt be any play were those buttons slide???
Old Nov 12, 2004 | 12:34 PM
Default clutch wear
one more quesion, how do you get the spider off?/?? I mean i know that there is a jam nut on top a big one that takes a spanner wrench so i made a spanner and i just cant get it off....i've used heat a hammer and punch...nothin...is it left hand rotation or what?? any suggestions??? thanks...
Old Nov 12, 2004 | 01:09 PM
CED's Avatar
CED
Default clutch wear
I believe it is torqued very high,like 150ft lbs or maybe even higher.
Old Nov 12, 2004 | 02:10 PM
Bubba297's Avatar
Default clutch wear
Yep, unless you have the holding fixture and the right removal socket with a big breakover or something like that then you wont get it apart without breaking something. Everything is torqued down very tight. They have to be considering the amount of stress put on things.
Old Nov 13, 2004 | 01:00 PM
Default clutch wear
well i made my own socket and impacted off the jam nut holding down the spider...now one more question how do you get the spider out of there now that i have the nut off...????thanks guys!
Old Nov 13, 2004 | 01:38 PM
SPORTSMAN70003's Avatar
Default clutch wear
I made my own spider & hold down tools took about an hour or so. The spider is really on there around 200 # torque here is some pics I went from to make mine.
http://imageevent.com/cobs/clutchtools
Old Nov 13, 2004 | 07:00 PM
Default clutch wear
thanks for the info sp700
