what engine mod?
Old Nov 14, 2004 | 09:37 AM
BOMBSAINT's Avatar
Default what engine mod?
well i have decided to spend more money. i am looking to add some type of mod to the engine. what i have now as far as motor mods is a hi-comp rwr piston, custom ported intake, and stock pipe w/ oversized baffle,repacked and endcapped. oh yea i also went up a size in jet after the pipe mods. i am looking to spend about 250.00-300.00. so the mod will not be major but just a little something to keep me moving in the right direction. i want to get the most for my money. any opinions or comments would be greatly appreciated.
Old Nov 14, 2004 | 09:44 AM
eRo's Avatar
eRo
get a used bigger carb ..
Old Nov 14, 2004 | 10:48 AM
SpinCycle's Avatar
If you still have the factory CDI that would be my choice.
Old Nov 14, 2004 | 11:05 AM
Eaglecollector's Avatar
Ditto bigger carb[img]i/expressions/face-icon-small-happy.gif[/img]
Out of EVERYTHING!! i have done to mine. The first carb upgrade i did was by far the most noticeable performace gain.
Old Nov 14, 2004 | 11:25 AM
SANDMAN430's Avatar
what sprockets are you running, and lookat losing some weight on the machine the little things are very helpful and are somewhat cheap.
Old Nov 14, 2004 | 04:13 PM
BOMBSAINT's Avatar
i run the stock size sprockets. i trail ride and occasionally get to take it out and open it up. i really dont have any problems with them. thanx though. the thought has crossed my mind.
Old Nov 14, 2004 | 05:34 PM
1BigDSRider's Avatar
Bigger carb. would be a nice power mod for you.
Old Nov 14, 2004 | 06:38 PM
crazypainter's Avatar
carb or CDI both good bang for the buck.
Old Nov 15, 2004 | 12:39 AM
JMAC650's Avatar
I would say carb or CDI as well. If you aren't hitting the limiter than go carb first.
Old Nov 15, 2004 | 11:11 AM
MrMeaner's Avatar
The carb and CDI are very good ideas. Are you running stock air filter? If so get an after market one and remove your lid. Gonna have to jet up. Also if your not running alot of top end go with a 15 front sprocket on front down one tooth. Rear tires maybe for traction? Just some ideas
