whats it take to get 500 to lift front end?
Old Nov 15, 2004 | 07:21 PM
TJCINC's Avatar
Default whats it take to get 500 to lift front end?
i have a 2001 500 4 stroke 4x4. i have a k&n air filter and have changed the primary clutch spring to a white. no matter what i do i cant get the front end off the ground. i weigh 210lbs. does anyone know if this is the proper spring. all motor and exhaust is stock. i want ot spend as little money as possible!!!!! [img]i/expressions/face-icon-small-wink.gif[/img][img]i/expressions/face-icon-small-sad.gif[/img][img]i/expressions/face-icon-small-blush.gif[/img][img]i/expressions/face-icon-small-disgusted.gif[/img][img]i/expressions/face-icon-small-blush.gif[/img][img]i/expressions/face-icon-small-sad.gif[/img][img]i/expressions/face-icon-small-wink.gif[/img]
Old Nov 15, 2004 | 07:46 PM
duneaholic's Avatar
I think that there is a technique to doing wheelies on automatics. Don't pull on the bars as soon as you gas it. Wait until you can feel the power come on then lean back and give a tug. It should come up no problem. I've seen guys that have automatics that just pull and pull on the bars when they are gassing it to no avail. Just wait a sec and let the power build then lean and tug.
Old Nov 15, 2004 | 08:04 PM
omahapredator's Avatar
i have a 2003 scrambler and can't keep the front end down when i gas it hard....all i have is a K&N and rejetted....that's it!
Old Nov 15, 2004 | 08:12 PM
Polaris500HO4x4's Avatar
thats odd.. i can get my sportsman to pick up no problem... ill have to have chuck take a pic of me doin a wheelie sometime ill throw it up
Old Nov 15, 2004 | 08:28 PM
TJCINC's Avatar
omaha-you have a 500 4x4 2003? what jetting did you go with?
TJCINC's Avatar
polaris500 , what primary spring are you using and whats your carb. jetted at.
Old Nov 15, 2004 | 08:29 PM
ftwflh's Avatar
My 500 Scrammy wheelies with no problem and I tip the scales around 225.Mine I have to be seated right and roll the throttle on and hang on.
Old Nov 15, 2004 | 08:36 PM
maddog56's Avatar
It takes a little more lead in your pants...[img]i/expressions/face-icon-small-smile.gif[/img][img]i/expressions/face-icon-small-wink.gif[/img]
Exhaust and air filter would be my first upgrades.
Old Nov 15, 2004 | 11:45 PM
TJCINC's Avatar
DOES ANYONE HAVE RECOMMENDATION FOR MAIN JET AND NEEDLE CLIP SETTING. AND ANY PRIMARY SPRING COLOR RECOMMENDATIONS?
THANKS
Old Nov 16, 2004 | 12:24 AM
i got an idea that i used before i got good... hold your brake in and left the power get to the wheels when that happens give it more so the tires slip and let of the brake and give~r~hell she will come up for ya
