2004.5 Sportsman 500 leaking carb.
Old Nov 16, 2004 | 12:04 AM
bjamin's Avatar
Default 2004.5 Sportsman 500 leaking carb.
Old Nov 16, 2004 | 12:12 AM
bjamin's Avatar
I have a 2004 Sportsman 500 with 155 miles and since new it has leaked fuel from the tube on the bottom of the carb (over flow / drain tube). The dealership has checked the floats and tighten the drain screw on the side of the carb bowl. As a last resort they gave me a new Mikuni carb however it still leaks. The leak amounts to about a pint of fuel every 30 to 35 miles.
Any suggestions would be appreciated ...
Old Nov 16, 2004 | 12:35 AM
Polaris500HO4x4's Avatar
wow thats alot of gas... and u have a new carb??? well is your intake valve opening enough
Old Nov 16, 2004 | 01:40 AM
Traildog's Avatar
Sounds like the needle valve that controls the gas into the carb is passing. Probably due to dirt in the valve or the valve is grooved but this is unlikely as it is a new unit. It might also be due to incorrect float level setting. If I were you as this is a new unit I'd let the dealer handle it.
Old Nov 16, 2004 | 10:36 PM
bjamin's Avatar
Thanks for the replies. The dealer is baffled but thinks maybe the needle and seat on these carbs needs time to adjust or seat so I guess I'll put more miles on it and see if that takes care of it. At least it runs great...
Thanks again.
Old Nov 16, 2004 | 11:47 PM
Traildog's Avatar
I don't agree with the statement of "needle and seat on these carbs needs time to adjust or seat". If it's leaking in needs to be disassembled and inspected. There are 3 possible fixes, the float needs to be adjusted to the correct level, the needle valve has something preventing it from seating properly, or lastly the needle valve and or the seat is damaged, maybe grooved and needs to be replaced.
My 2 bits.
Old Nov 16, 2004 | 11:49 PM
how can this be carb related if it did this on your old one and now its doing this on your new carb????? i dont get it
Cole Hadden
Jun 15, 2025 09:05 AM
GregM
Jul 29, 2015 09:41 PM
ghost civic
Jul 27, 2015 03:15 AM
Sandman2.0
Jul 21, 2015 09:03 AM
Unzzy66
Jul 11, 2015 10:01 PM
