ACTUATOR NOISES P700
Old Nov 16, 2004 | 10:39 PM
BCNUCS's Avatar
Default ACTUATOR NOISES P700
Hey guys, just got my 2004 prarie and I am very impressed. Just wondering since I bought it used and all. The actuator on the right side of the quad is very noisy. Is that normal? I just put my 27" GY mud runners on, should I do anything to my clutch springs(primary or secondary) before long?
Old Nov 17, 2004 | 12:16 AM
WileyCoyote's Avatar
Yeah, they're noisy. You'll hear it cycle as soon as you turn the key on. It's when you don't hear it anymore that you probably have a problem.
Old Nov 17, 2004 | 08:29 AM
turbojosh's Avatar
I have a 700 prairie and mine makes alot of noise after i get in really deep water and really deep mud and ride it real hard in those conditions. Is there anything i can grease down to get it to quieten down.
It sounds like it is confused and squeals?
Old Nov 17, 2004 | 10:10 AM
MikeyBoyesq's Avatar
Yeah, you can remove the little black cylinder shaped (metal) cover on both the KEBC and 2wd/4wd actuator (there is a little electric motor underneath) and clean it out real good and then put it back together. If its leaking, you might want to use a little silicone on the edges of this cover to seal it when you put it back together so as to keep the mud/water out of it in the future.
Happy trails...[img]i/expressions/face-icon-small-smile.gif[/img]
Old Nov 17, 2004 | 06:28 PM
BCNUCS's Avatar
hey turbo josh, i noticed you have the black spring. Was it hard to install and does it help restore power from stand still with the 27" tires?
Old Nov 18, 2004 | 09:06 AM
turbojosh's Avatar
BCNUCS
I like the black spring i installed it in about 40mins. It wheelies alot easier and it is kinda snappy off the line. I could wheelie from a stand still to about 40 mph and it would come down before the black spring.
When i installed it i can wheelie to about 30 or 35 from a standstill. It is a lot of fun now.
You can't go wrong installing the black spring.
mrtidy
Feb 3, 2016 05:00 PM
Roro
Ask the Editor
Sep 30, 2015 10:58 AM
Ahtatu
Sep 28, 2015 12:14 PM
kbazzy
Sep 26, 2015 11:26 AM
