why does my banshee lag top end?
Old Sep 5, 2000 | 01:20 AM
bansheepower's Avatar
I have a 2000 banshee and i just disconected my throttle postion sensors because they went on the machine. now that i have done this there seems to be some lag throught the gears. My top speed on the demon is 55. Any respeonse will help. thanks
Old Sep 5, 2000 | 04:07 PM
sAyIt_fmf's Avatar
Do you have the Throttle Stop screw turned all the way out? I believe they come close to 3/4 from the dealer.
Old Sep 5, 2000 | 08:22 PM
SandmanBlue's Avatar
You disconnected the sensors because they went on the machine????? Huh???
If you reconnect it, does it fix the problem?? Disconnecting the TORS won't make your quad faster. It's only designed to cut the throttle in case of an extended WOT no load condition that could cause engine damage.
It sounds like you unplugged the wires that connect the TORS to the thumb throttle. You can't just unplug something and expect all else to work. If this is what you did, then you actually caused the TORS to think it needs to kick in. It's now interrupting the ignition, which is what it is supposed to do.
Old Sep 5, 2000 | 09:41 PM
i dissconected my senors because they went on the carbs all the machine would do is bog, my buuddy that works at an atv shop told me do do this in order to bypass them thanks anyway
Old Sep 5, 2000 | 09:57 PM
YaMaRaPtoR's Avatar
Id ask your 'Buuddy' to look at it. not some one a thousand miles away, Sounds like you should reconnect what you disconnected.
Old Sep 5, 2000 | 11:20 PM
ridzhard's Avatar
Check the wiring that goes from your right hand, to your head, and then to the seat of your pants.
Old Sep 5, 2000 | 11:35 PM
my buddy was there when i did and it ran great has nothing to do with the sensors, what else could it be
Old Sep 6, 2000 | 12:08 AM
DunePilot858's Avatar
Have you cleaned the air filter lately? Did you make sure you didn't turn any adjustments on the carbs when you unhooked the things that really didn't need to be unhooked. Make sure the black tube between the two carbs are hooked to each carb. Replace your plugs. Adjust your premix ratio. Change your gas. Clean your carbs... and lastly slap your friend across the face and tell him never to touch your bike again
Old Sep 6, 2000 | 11:25 AM
chode i have done all of this do you think the carbscan be out of sync
Old Sep 6, 2000 | 01:17 PM
sAyIt_fmf's Avatar
When you unhooked the electrics, Did you change the carb caps at the same time?
Turn the adjustment on the throttle splitter cable?
Your carbs could be out of sync, Or not opening all the way.
Kaleb_00
Jun 1, 2016 09:15 AM
greek271
Aug 8, 2015 08:16 PM
JohnnySplat
Aug 6, 2015 12:07 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
Jul 7, 2015 11:00 PM
