NEED HELP
Old Nov 18, 2004 | 01:11 AM
VAP1507's Avatar
Default NEED HELP
I have a 425 xpedition. I have been using it on the farm and realy like it . But this last weekend I joined in a serch for a miss girl, and found out that I need a higher mouted light. The lights in front are to low and grass block them out. I found a spot light that mounts on handlebars but it is 75000 candle power is this to much. Allso when the cooling fan starts up the lights dim is this normal? I have 4200 miles on this atv and it run great but I have never ran it alot at night also if their are any mod that would help out I sure could use them. thank JOE Z
Old Nov 19, 2004 | 12:21 PM
CmdrBen's Avatar
Default NEED HELP
Maybe you could mount a light pod from a Sportsman?? I think it'd fit without too much trouble, but I really don't know.
I'd say the lights dimming a bit would be normal, but you should probably check out the charging system to be sure.
