big bore kits?
Old Nov 18, 2004 | 04:38 AM
2FAST4U69's Avatar
Default big bore kits?
How much could I increase the displacement of a raptor 660 without losing too much reliability?
Old Nov 18, 2004 | 04:41 AM
pendejo's Avatar
Probably the 686 or 690 kits are gonna be the most reliable.
Old Nov 18, 2004 | 08:37 AM
ItalianStallion's Avatar
The most reliable..IMO..would be a low compression 686/690...you can even go a low compression 727/730...very reliable also but that one would have to be done by a builder because it needs to be sleeved and you would need a new rod and balancing as well as new valves and a such...a good cryo coating on either motor would also help it outlast alot of home built stuff.
Old Nov 18, 2004 | 10:34 PM
Kenzcycle's Avatar
The 686cc kits work really well with the right cam,the 727cc makes lots of bottom end.You should set a budget to work with,and shop around.Relaibility should not be an issue with either build if done correctly.
Quadzilla Heritage
Sep 25, 2015 01:39 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
Alex G.
Sep 16, 2015 12:13 PM
Lou Domenech
Sep 11, 2015 06:35 PM
