P700 Skidplates and Plow?
My Warn plow mount did not work without a few modifications to my Ricochet skid plate. I had to cut some notches out of the side where the skid plate wraps around the frame with the clips and drill two holes for the u bolts. It has not caused a problem with the function of the skid plate that I have noticed and I just put the plow mount back on Sunday.
I have the Ricochet skid plates and a 60" Cycle Country plow... I just cut about 3/4 inch notch in my skid plate to allow for the plow mount. I keep my plow mount on all the time, and use a stack of washers on the slip plow mount pins to keep from damaging the mount points when I'm bouncing off of tree trunks or rocks. Works like a champ!!!
With the Cycle Country plow mount, I can install / remove the plow in about 2 min tops! Mine has the little electric lift motor attached to the plow. LOVE IT!!!
That sounds doable! I have a couple of options. I was thinking I needed a lift kit, because I had a Warn Plow and damaged the mount riding rocks and didn't want to do it again, especially after putting in a skid plate. I thought that would lower the clearance.
kampswas
Sep 23, 2015 05:05 AM
TheATVSuperStore.com
TheATVSuperStore
Sep 9, 2015 07:43 PM
