94 400l
Old Nov 25, 2004 | 10:25 AM
50lyj's Avatar
Default 94 400l
Hi everyone,,, I just got a 94 400L 4x2 last week on trade.. i can't get it to run.. I checked the spark, compression, and it smells like it getting fuel... It'd got good spark and 125 PSI.. Does anyone one have any ideas????? It cranks good... Plus I have 2 hoses coming off of the carb and they are just hanging there, anyone know if that is right or should they be connected to something.. I just ordered my manual for this 4-wheeler, but i would like to get it runing this weekend if i could.. [img]i/expressions/face-icon-small-confused.gif[/img] [img]i/expressions/face-icon-small-confused.gif[/img] [img]i/expressions/face-icon-small-confused.gif[/img]
Old Nov 25, 2004 | 11:25 AM
ftwflh's Avatar
Default 94 400l
Take the carb off and clean the jets out.
Old Nov 25, 2004 | 11:43 AM
50lyj's Avatar
Default 94 400l
i just did that last night, so here in a few I'm going out to put it back on to see if that works... But i don't know if that'll work or not the carb was clean inside.. we'll see thou......
thanks
Old Nov 25, 2004 | 01:17 PM
50lyj's Avatar
Default 94 400l
Well any other idaes???? cleaning out the card didn't do any good... i'm thinking that i might not have enough spark... i can see it but it's not the best spark.. does anyone know how to adjust the magneto??????? what would the thickness be????
thanks
Old Nov 25, 2004 | 05:15 PM
ftwflh's Avatar
Default 94 400l
Try a NEW plug and fill it up with FRESH gas.Always eliminate the easy stuff before panicing.
Old Nov 25, 2004 | 05:22 PM
BigBadScrambler's Avatar
Default 94 400l
If it has a fuel filter on it then I would swap that out too. New ones are only a few bucks at the auto store. Who knows how old it is.
Old Nov 26, 2004 | 12:08 PM
50lyj's Avatar
Default 94 400l
OK new plug and fresh fuel... new filter.... any other ideas???? i'm still kinda puzzled....
i appericate all the ideas but it still will not start.. i have never found a motor that will not start before..
thanks
Old Nov 26, 2004 | 12:20 PM
POLARISFREAK's Avatar
Default 94 400l
Does it try to fire at all? If you've got gas and spark the only other thing it needs is oxygen. Did you make sure there is no restriction in the intake or exhaust?
Old Nov 26, 2004 | 02:32 PM
50lyj's Avatar
Default 94 400l
Yes it sparks.. I figured that it should start to run even if it had a little bit of fire.. the intake is goo but i haven't checked the exhaust yet..
I'll check that then get back to you....
thanks
Old Nov 26, 2004 | 04:04 PM
braveops's Avatar
Default 94 400l
maybe bad reeds?
