Oil capacity of 400EX, 450R, and YFZ450
Old Nov 25, 2004 | 05:54 PM
oldturtle's Avatar
Default Oil capacity of 400EX, 450R, and YFZ450
We had topic on reliability of these three quads. My 400EX will take 2.0 quarts without overfilling. The owners manual lists only 1.8 qt after drain and 2.3 qt after disassembly. I was wondering what are volumes of seperate motor oil and tranny oil in 450R and combined oil in YFZ450.
Even though the 400EX is not water cooled, it has a very large oil cooler, a large volume of oil, plus a dry sump with seperate oil tank. Honda says the seperate oil systems on the 450R avoids contamination of motor oil with clutch debris and avoids problem of oil breakdown due to tranny gears.
I'm wondering if anyone has thoughts on volumes of oil in these three quads and the resulting reliability comparison.
Old Nov 25, 2004 | 06:02 PM
ridinredODB's Avatar
my 450R holds less than a quart of oil in the motor. the tranny takes about 4/5ths of the honda red bottle tranny oil.
Old Nov 25, 2004 | 09:08 PM
HughJazz's Avatar
the YFZ hold about 2 quarts
Old Nov 25, 2004 | 09:48 PM
buck183's Avatar
I've seen a lot of things in my 35 years of life, but I have yet to see the amount of oil an engine can hold affect the longevity of it.
This thread just may take the cake.
Buck
Old Nov 25, 2004 | 10:35 PM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
The manual says the 450R holds 0.82 qts. in the engine, and 650 cc in the trans.
"<B>Separate oil:</B> The benefit of separating the oil, like Honda does, is that the top-end is not contaminated by clutch debris or broken teeth. Additionally, the heat of the combustion side does not thin out the transmission and clutch oil. The CRF can use an MA-series oil in the transmission and slippery MB-series oil in the top-end.
The downside is that the oil quantity in each chamber is reduced (to approximately 650cc), increasing the need for more frequent oil changes. Any oil loss, no matter how small, becomes critical when you have a small pool to draw from." http://www.thumperfaq.com/oil.htm
XxS0ccerstarxX
Sep 24, 2015 11:53 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
Sep 23, 2015 06:23 AM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
