I NEEED HELP FROM SCRAMBLER 400 OWNERS!!!!!!
Old Nov 27, 2004 | 10:57 PM
scrambler322's Avatar
Default help
Hi everybody i need your help i am going to glamis in feb to ride i went last feb and took a worked raptor and had no problem making my way up any hills. i was going to buy a used banshee but came across a super deal on a 2002 scrambler 400 2x4, but it does not have enough power stock for me to do what i want to do out in glamis all my friends have worked quads and i will be left in the dust. i have some ideas what to due to make the bike faster but i would like some input from fellow scrambler owners. thanks. [img]i/expressions/face-icon-small-smile.gif[/img][img]i/expressions/face-icon-small-wink.gif[/img][img]i/expressions/face-icon-small-sad.gif[/img][img]i/expressions/face-icon-small-wink.gif[/img][img]i/expressions/face-icon-small-smile.gif[/img]
Old Nov 27, 2004 | 11:09 PM
2manytoys's Avatar
Default help
The Scrambler is capable of 80+ hp. I have seen these moded like crazy and nothing can touch them. There are alot of guys on here that have moded 400's. Go to www.hpd-inc.com. Everything you need for a bad a$$ 400.
Old Nov 27, 2004 | 11:30 PM
Default help
thanks for the reply i was looking at aaen performance for mods, i was just going to ad a 38mm carb, pipe/silencer,rad valve,k&n filter and clutch kit it states it will get you around 52.5 hp. i would like to leave the motor stock for reliablity. i'm trying to get the bike to around the same as a stock banshee does anybody know if the mods i listed is enough.
Old Nov 28, 2004 | 01:02 AM
BigBadScrambler's Avatar
Default I NEEED HELP FROM SCRAMBLER 400 OWNERS!!!!!!
Go for the HPD trail Mod (around 65hp) if you dont want to go to radical. You are going to want to at least put a Wiesco piston in it if you plan on modifing it. The stock piston wont last that long.
Old Nov 28, 2004 | 01:09 AM
Whitedog's Avatar
I personally dont think youll benefit all that much from the carb unless you port the cylinder. Instead of spending 250 on a carb, you should pull the jug, get it ported and install a wiesco piston. - The stock pistons break. - With a good pipe, clutching and and a good port job, you will handle stock shees easily.- my 2c
Another good site is Arizona bad boys.
Good luck!
Old Nov 28, 2004 | 10:27 AM
scramblered's Avatar
to compete with a shee i highly suggest HPD race mods combo with a major
lightening up if you really taking it seriously,,,a streched swingarm
is a must have,,wider a-arm,,hot seat suspension kit (spring,fox shocks)...
let us known what you choose,,
Old Nov 28, 2004 | 12:37 PM
ftwflh's Avatar
What you are wanting is a good start at blowing away a Banshee.Aaen is a good company with good tech service.They wont steer you wrong.I think they are as good as HPD or Hotseat.I would think seriously about pulling the jug and putting in a wiesco piston for safty reasons and while it is apart have it ported.
Old Nov 28, 2004 | 03:36 PM
braveops's Avatar
[quote]
i thought i was only 50-55 hp for the trail mod??
Old Nov 28, 2004 | 03:51 PM
OneBadPolaris440's Avatar
Are you planning on just buying and installing it yourself ..... ? ....... Check out AZ BAD BOYZ ....
Old Nov 28, 2004 | 03:55 PM
And yeah the hpd trail mod puts out about 50 to 55 hp
