wheel spacers for Yamaha Raptor 80?
Old Nov 28, 2004 | 02:47 AM
rockettmom's Avatar
Default wheel spacers for Yamaha Raptor 80?
We just purchased a Yamaha Raptor 80 for our six year old son. Would it be a good idea to put wheel spacers on the quad? Does it make it a bit safer? If so, any recommendations on what and where to get them?
Old Nov 28, 2004 | 02:17 PM
VelociRaptor350's Avatar
A wider wheelbase always makes a quad safer, its more stable and less likely to tip. You can probably get wider tires and accomplish the same feat. Check ebay for spacers.
Old Nov 28, 2004 | 04:43 PM
rockettmom's Avatar
Are there any specific wheel spacers that are safer than others? Any name brand I should know about? Are there different types of wheel spacers?
Old Nov 28, 2004 | 05:45 PM
BryceGTX's Avatar
VelociRaptor350 is right about a wider track being more stable. However, it is not a good idea to put wheel spacers or reverse offset wheels on a quad. Spacing the wheels out on a stock suspension puts more stresses on the axle, bearings and front suspension members. In addition it changes the front end steering geometry thereby adversely affecting the handling. It is not a good idea to use spacers to widen the front track width. Hope this helps.
Old Nov 28, 2004 | 06:38 PM
rockettmom's Avatar
Is there any way to make the quad more stable?
Old Nov 28, 2004 | 07:49 PM
Longer A armns up front and a wider axle in rear, but that costs alot of $$$$$
Old Nov 29, 2004 | 08:33 AM
maddog56's Avatar
Not availible on a Raptor 80, uses different suspension.
Spacers should be fine for racing, but I'd be weary of mx. You want a spacer with integrated studs, not stud extenders. They are much more stable and strong but also typically a little more money.
Old Nov 29, 2004 | 09:10 AM
rockettmom's Avatar
what's mx?
Old Nov 30, 2004 | 01:25 PM
maddog56's Avatar
Originally posted by: rockettmom
what's mx?
Motocross
Old Nov 30, 2004 | 05:31 PM
Bradracer18's Avatar
That little predator 90 of Doug Nicholas's(on the website) is pretty wide......I wouldn't think you would tip it over very easy..........I can't tell for sure what they did to it........it might just have offset rims like that......
black_thunder
Jul 12, 2015 11:04 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
yambam13
Jul 4, 2015 01:49 PM
